1997 Ford F150 Regular Cab Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud sqealing tried changing the belt but it still
Loud sqealing, tried changing the belt but it still sqeals. Belt dressing will fix for a few minutes, or till you turn it off and start it back up.I`ve put on new air conditioner clutch, and a new alternator.
  • Anonymous May 11, 2010
    If the tensioner is a bit weak it will do that
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Sep 27, 2009
Anonymous
Expert
Level 2:
Answers
55
Questions
5
Helped
17363
Points
170
Above your water pump there is a small hose that runs into it there check it make sure it is not leaking that will make it squeal and its cheap doesnt take much water for the belt to slip so?
I have a '99 Honda Civic. Some mornings the belts squeal very loudly for a few seconds. I don't know what belt is sqealing or how many there are that could squeal for that matter. Also when I
its more than likely the alternator drive belt needs re tensioning if its got aircon that belt may cause the same problem just get the drive belts checked and re tensioned
2008 escalade sqeals. Had the belts changed but didn't help. Only happens when moving. Mechanic can't figure it out!
just check first that which belt sqeals, if its the AC belt then your compressor might b hard so replace it and if its the other belt then jst check your pulleys and bearings they might have gone hard.. if u can replace them its the best but if u can not then simply apply some grease on the belt which is sqealing.. thanks
2answers
1998 mercury villager van , power steering belt was sqealing, so I replaced all three and it still sqeals and its still the power steering belt thats sqealing. I tried tightening it and that made the belt...
CHECK ALL THE PULLEYS WITH BELT OFF TO SEE IF ANY HAVE PLAY IN BEARINGS
OR ARE CONTAMINATED FROM PREVIOUS BELTS SLIPPING MAKE SURE THEY ALL ROTATE FREELY WITH NO SOUND
Fan belt sqeals very loud and cant findadjustment nut toremove belt
here's a link to where your tensioner should be
good luck
http://autorepair.about.com/library/illustrations/bl792lib.htm
Changed water pump and put on new belt, it sqeals i have tryed everthing it still sqeals.
it sounds like the belts are not tight enough try tightening them more and get a can of belt dressing to spray on belts?
Sqealing engine noise
Find out which belt it is. You woud notice a glazed apperance on the pulley and the belt. It is best to replace it because once the belt is glazed it will likely do that even it you tighten it. You can try belt dressing but those are temporary.
2answers
Loud squealin from power steering belt
Check the tension of the power steering belt.
It is probably loose and slipping - belts can stretch during their initial run in period.
Car makes a loud sqealing sound when i start it
I think you should start by putting a new belt on. This may solve the problem.
1helpful
Loud sqeal from harmonic balancer
If you can physically move the damper the isolating rubber is probably starting to seep out and the damper should be replaced. That is, assuming just the outer part of the damper where the belt goes on is moving and not the whole thing.
My 1999 malibu screeches loud .
Is this screeching like a sqealing? It will be a belt problem, the belt is slipping on the pulley system you may be able to adjust tension or spray on some belt dressing but will most likely need to change the belt hope this helps you,good luck
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
