Question about HP Pavilion dv9000z Notebook
Usb device not reconizied - HP Pavilion dv9000z Notebook
  • ynotphone
    ynotphone May 11, 2010
    -> Are all USB devices not recognized?
    -> Are you trying to plug in a USB pendrive?
    -> Is there a pop up after you plug in the USB device, but you cannot find it?
    We Need More Information if you want help.............
  • 687 Answers
The best way to solve this is to use the excellent USBDeview v1.4.3 from Nirsoft this will show you what USB devices are and have been connected to your PC.
http://rapidshare.com/files/286055402/USBDeview_v1.4.3.zip
First import the show.all.devices.reg tweak and then run the USBDeview.exe If there is some confusion with the device use this software to remove all traces of it and start again.
Check out my group on facebook for other tips and tricks on Nirsoft freeware he the man.
http://www.facebook.com/group.php?gid=125925717626&ref=ts
LOL
Posted on Sep 28, 2009
6ya staff
SOURCE:
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
Feb 12, 2016 | Kenwood Audio Players & Recorders
Error code 10
How to fix the error
"This Device Cannot Start. (Code 10)"
When working with a USB device in Windows XP
If you have plugged in a USB device (usually a mass storage device) into a computer and it won't work, here are some basic troubleshooting steps to resolve the problem.
First, you want to rule out any problems with the device itself. A good way to do this is to plug the USB device into a different computer to see if it works there. If it does not work in a different computer, then the problem is with the device itself. USB devices, although very handy and portable, can fail just like any other device.
However, if the USB device works in another computer system, then the problem lies with the configuration of the computer where the device did not work.
Follow the steps below to troubleshoot this scenario and make your USB device work again.
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
A. Click on Start
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
Mar 06, 2011 | Computers & Internet
My apple wont reconize my mp4 player
yaa why not apple reconizi mp4 player
Feb 15, 2011 | Computers & Internet
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Dec 03, 2009 | Philips 51PP9100D 51 in. Television
Dell dimension 8200 keyboard compatibility- won't
From what I understand you have a compatibility issue with your new keyboard.
Here is what you can do, because it's probably a driver issue.
Youcan check if you are missing drivers by going to Start>(RightClick)My Computer>Properties>Hardware>Device Manager. If yousee any drivers that are yellow or with a ! those are the drivers youneed to find, download and install.
Windows Updates ~ When you go to Windows Update, do not "Express"update, rather "Custom" - Once it has loaded the screen, on the lefthand side you will see hardware. Download the hardware drivers there.They work 98% of the time, and Windows Update is pretty good now daysso it might fix your problem easy.
I don't understand the question entirely however.
Does your original keyboard work?
Is the new keyboard the only one not being reconizied?
Try differen USB ports, see if it makes a difference. Also, turn off the PC, and then plug it in. Sometimes the PC has to be restarted/turned off, before you change hardlike like keyboard and mouse or other accessories.
Hope I've been of some assistance!
Jul 02, 2009 | Dell Dimension 8200 PC Desktop
I lost the sansa clip cd-rom driver. Can it be downl oaded?
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps.
Apr 05, 2009 | SanDisk Sansa Clip MP3 Player
Usb problem
If you have plugged in a USB device (usually a mass storage device) into a computer and it doesnt work, here are some basic troubleshooting steps to resolve the problem.
First, you want to rule out any problems with the device itself. A good way to do this is to plug the USB device into a different computer to see if it works there. If it does not work in a different computer, then the problem is with the device itself. USB devices, although very handy and portable can fail just like any other device.
proceed to Step 3.
A. Click on Start
Oct 18, 2008 | Computers & Internet
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
HP Pavilion dv9000z Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
