If you can see the frame numbers on the edge of the unexposed negatives, the problem is most likely either the camera's shutter is not opening, or the camera's take-up/advance mechanism isn't working properly. It could also be that the film isn't being loaded correctly. Check all three, or have a camera shop (not department store!) check it out for you. They should be able to test the first two situations easily, and help you if it's a loading problem.
