Dough hook stuck in machine
Hi. Is it possible that some of the dough or flour you are mixing has made it's way into the attachment point with each batch, and therefore gumming it up progressivley ? Carefully lay the mixer on one side, being carefull not to lay it on the side mixer controls. Use a rolled up towel to support the head, this will make it easeir to see the attachment point. If there's a buildup of flour, wet it with warm water and a little liquid soap, until it softens, remove the attachment and clean the areas of contact. Apply a bit food oil to the hook before using next time.
Re: your second mixer The head locking pin may also have flour in it. This would inhibit the movement of the locking mechanism along it's guides. You may have to do some disassembly to get it cleaned out. After cleaning put a drop of regular oil on the moving parts. Be sure to clean the recess that the pin fits into as well.
If that's not your problem, then the pin may be worn enough to not fully engage.
If I have assisted you, please rate my solution. Good luck! ricardok45
