1ST IT IS NOT A MOTOROLA PIECE. IF IT IS A MOTOROLA PIECE I APLOGIZE BUT I MAKE THE HFBLU-10K. IF ITS A CELLULAR INNOVATIONS HFBLU-10K YOU CAN EMAIL ME AT [email protected] AND I WILL SEND YOU A COPY OF THE MANUAL
for iphone : set your phone to scan for wireless device 1 unlock 2 settings icon 3 general 4 bluetooth ON the hold the big button on the blue tooth once it flashes blue DO NOT LET GO! keep holding it till it flashs red and blue red and blue then let go and it should find it instantly then press on the BK-600 word and enter the 0000 code and you should be all set.
yes, this item is definately compatible to the iphone. try this:
1) turn bluetooth unit completly off
2) make sure bluetooth function in your phone is turned on
3) from the off position hold down the (mfb) or power button as if you were turning on the unit
4) you will see a blue light indicating the btooth is powering on DO NOT LET GO OF BUTTON
5) after blue light you will see red and blue light start to flash together..when you have achieved this state you can let go of the button
6) go to your phones btooth menu and go to where it says add a device or search for devices(terminology different in every phone)
7) your phone should search and find it, it will come up as hfblu-10k.. after it finds it just follow the prompts your phone gives to complete the set-up. FYI password is "0000"
I was given this bluetooth after a buddy of mine could'nt figure it out. I figured out how to sync it by following that longer than 5 secs. idea that's posted here. I did'nt have a manual so I just put in "0000" and it worked! So try that...Good Luck. Thanx4Hating
For Cellular Innovations Mini Blue HFBLU-AX1C. To Pair with Your Phone....
1. Turn OFF Bluetooth Headset 2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode) 3. Search bluetooth device through your mobile phone. 4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
