2002 Acura 3.2TL Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please help....I have a 2002 Acura TL Type S. The cruise control just stopped working. I push the buttons on the steering wheel, but no lights on the dash and the cruise control never engages. I checked the fuse under the dash and it is good. Any feedback is greatly appricated. Thanks!
Anonymous
Level 3:
  • Master 811 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
Answers
811
Questions
0
Helped
296070
Points
2322
Check under hood for other fuses or relays
1helpful
2002 T & C Cruise Control Problem
Do you have buttons on the steering wheel for the cruise control ? Does your horn work ? There is a component under the steering wheel , on top of the steering column , called a clock spring ! I will include a video on it . Chrysler Van Clock Spring
The vsa Light is on and it don't wanna accelerate
Did you check to see if you accidentally pushed the VSA button (left side of steering wheel on dash)?
Acura tl cruise control
check fuses at drivers foot area and clean pickups on front half shaft driveshaft nearest to wheel, and wipe off the pickup and make sure it is plugged in.
Intermittant cruise control on 2004 Acura MDX
Sounds like it is a senor module out of alignment either for the brake or accelerator. should be somewhere around the upper arm of both, try adjusting them may just be out of alignment is all.
Cruise control doesn't work.
before replacing anything, check the cruise control fuse under the dash and under the hood the fuse box under the hood should be close to the battery
4helpful
Cruise control can not set speed but cruise ctl light is on
Sometimes the plastic cog on the side of the throttle body (TB) breaks. This cog is "pulled" by the cruise control accuator's cable.
To check, simply look on the side of the TB and check to see of the cable end has broken free. (The mechanisim is much like the brake cable on a bike)
2002 Honda Accord EX V6 cruise control failure
http://www.handa-accessories.com/accord/accswc.jpg
So after you push the button and then press the set button in the steering wheel it does not get into cruise control ? It sounds like a minor electrical problem. If you have warranty still I think the dealership should fix it for free.
Sorry i have not been able to help you.
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
