Dryers Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer will not start. Performa Series MED 5640TQ0 TYPE DWSR ELE 2406026 FM54
Don Webb
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 30, 2013
Don Webb
Contributor
Level 1:
Answers
Questions
0
Helped
1817
Points
0
Nothing happens when push start button.
All limits are good.
Element tests at .001 ohms.
  • Louie Jimenez Dec 31, 2019
    How much for ele-2406026-fm54
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Jan 01, 2020
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
740800
Points
5402
Anonymous
Level 1:
New Friend:
  • Posted on Jun 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1817
Points
I can't get the button to go on to start the dryer, the button doesn't press in.
My whirlpool dryer DWSR-ELE-2406026-FM54 is making a rumbling sound and a burning smell when turned on what could it be
might want to check your lint filter. After that check your exhaust tubing incase lint has escaped into the exhaust tubing. This stuff can catch on fire if it gets out free or stuck in your dryer tube.
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 • Dryers
DRYER WILL NOT START. WHIRLPOOL MODEL WED5821SWO SN MT3502452 TYPE DWSR-ELE-2406026-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have a maytag dryer (dwsr-ele-2406026-fm54) and all of a sudden it will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 • Dryers
1helpful
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 • Dryers
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
