I was sewing along fine for about two feet, then the needle jammed and had to be taken out. I cleaned the shuttle race and put it back in the machine (according to illustrations on p. 39 of manual). When I turn the wheel by hand w/o using the foot pedal, the needle works fine, but as soon as I step on the power, it jams.
I've taken the shuttle pieces apart and reinserted them about ten times. Each time, I think it will work, but it jams every time. Is this a timing problem?
Thanks
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Had same problem. took thread out...that worked. thanks drazil
Is your bobbin too full? Sometimes I have to take thread off my bobbin because of jamming problems. Sounds crazy but it has worked for me.
The needle timing with the shuttle was off. About the 12th time I took it all apart, I got the needle adjustment right. Thanks.
My Kenmore 385 is doing the same thing. I'm only on the 5th attempt right now.
I have the same problem!!! its so frustrating...I have the kenmore 385-15408.
I changed the needle thinking it might be bent (it was) but that hasn't helped. I cleaned the shuttle race about sixteen times thinking there might be some thread or lint in there. I lowered the tension on the bobbin holder bit. I have taken the whole shuttle/bobbin setup apart about twenty times, but it's still jamming on me.
How can I fix it???
