Televison & Video Logo
Posted on Sep 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
43fdx15b Hitachi 42in rear projection tv. been a great tv. I think it was jarred, and now the left side of screen has red vertical lines, farther apart on left side, getting closer together and disappearing in the center and right side. the Magic focus button works for the other colors but seems to lock up on the red. Help?
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Sep 26, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
149993
Points
2098
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
NO RED COLOR ON A 43FDX15B HITACHI 52
3 reasons for this.
1st reason the fluid is contaminated and thats why u dont get red.
2nd reason no red drive possibly due to a bad colour driver on the base of the tube neck.
3rd reason the tube is out.
1helpful
I have an Hitachi 43FDX15B. The tv worked perfect
sounds like the convergence is out of whack. you will need to call a local repair shop and see if they can realign the color guns inside the unit. this is actually a really common problem with moving a rear projection screen.
Hitachi 43FDX15B has a red tint...
This can be caused by a few things. The red crt/picture tube is going bad, which it would have to be replaced, tube can cost anywhere around $195 and up, if it is available. Another problem can be a bad transistor or IC on the red crt circuit board. Either way it should be taken to a repair shop. The average cost for repair could be over $300.
1helpful
Hitachi rear projection double image goes away when tapped
Your convergence chips are bad. You can set a repair kit from www.TvRepairKits.com for your model. Their kits come with all the parts and a complete photo instruction guide.
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Hitachi Mode; 53UDX10B
http://serviceman.site88.net/index.htm
Hitachi 43fwx20b
Your vertical amp is failing and you will have to get it replaced. If your TV is under warranty, i suggest contacting the shop or manufacturer and get it fixed/replaced.
If not, then you will need to contact a qualified TV repairman to replace the vertical amp for you, as i wouldn't recommend opening the TV set to try a DIY..
Hope that helps. Should you have any further queries, pleas post back, and I will try to assist you as best I can..
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
