No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Could be the bearings going, other possibilities could be that the drum is slightly misaligned and scraping against the housing, although that's not very likely, or a bad belt.
Although sometimes it's some obscure thing, I could be compleatly wrong.
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Hello. The dryer has a belt running around the entire tub and that belt also goes over an idler pulley which keeps the tension correct. When you get that high pitched squeak the fix is to replace both the belt and the pulley. If you go to searspartsdirect.com and enter your dryer model number you will get the schematics for your dryer which will show you exactly where these parts are. You can also order new parts from that site if you choose. Regards, Joe
check what is called an idler or tension pully. lubricating these can somestimes help but only a temporary fix. actualy its not a fix. only makes it quiet. replace them or call service these parts are easily accessable
You can generally access the unit from the rear panel. Try and lube the joints around the pully for the belt and any other moving parts. Hopefully you won't have to replace any parts. Good luck
