Question about Avanti ER2001G Kitchen Range
This is a brand new range and the elements do not get red. Uncovered water will not boil and covered water takes nearly an hour on high. The oven does not get hot enough either. I just moved into this apartment and all the appliances are brand new including this range. The landlord does not have the papers for this range. The building is fairly new and the wiring is up-to-date. Is there something that needs to be done with the settings? Is it a bad range?
  • Pierre jo Dec 02, 2012
    I am experiencing the same issue with the same item - I've filled a small pot with 2 liter of water nd have left it on the biggest burner for 40 minutes at max and it barely has bubbles inside but NO BOILING.
    Same issue / same brand here. Water on biggest burner set on HI will not boil. same on other burners.
    Scholar:
  • 43 Answers
Ranges/Ovens use 220-240 Volts of power instead of 110-120 for most appliances. This is because you are converting electricity to heat. And in that process, you waste a lot! Resistance is what causes the heat to build, the more resistance to the flow of electricity, the more heat is generated. I am thinking that you are not receiving the correct wattage and or amperage to this appliance. Could be a bad cord, a bad connection inside the stove, or only a small amount of voltage coming to the plug. You would need an electrician to determine if you have 220-240 volts and at least 40 amps at the outlet where the stove plugs into. Volts are the flow of electricity, and Amps are the strength, or pressure. Without the both, you have very dim lights, slow running electric motors, and inoperable appliances. If there is indeed 220-240 Volts and 30-40 Amps at the outlet where the stove plugs in, then there are problems with the wiring inside the stove, or the elements themselves. Possibly, but unlikely, it could be the control panel, but you state it's fairly new. Hmmmm, sounds like low voltage, low amperage, and time to investigate both the outlet and the stove. You need an electrician, or someone really familar with electrical. This is important. This is not a mild shock, and a tingle up the arm, if they don't know what they are about, the amperage and voltage could be deadly. Not for the untrained. Have them check the outlet for the stove, and then the stove itself. Simple checks, and you should find it very easily. And, if the outlet checks out okay, then I would return the stove to the seller, and demand a replacement, since you say it's NEW. It's gotta warranty. Let the store take care of it's problem. You got cooking to do! Hope this helps. And PLEASE, Be SAFE. Don't attempt to check this outlet if you are not qualified and expierenced with electrical matters. It can be deadly, and permanent. Like going from holding your garden hose and washing your car, to trying to control a 2" fire hose from a fire truck pushing 600 gallons of water a minute. Thats just an example, but the theory is similar. Lots more volume and lots more pressure! Only this pressure and volume can ruin the rest of your life. Be Safe. Be Aware. And Happy Cooking Soon!
Posted on Sep 26, 2009
6ya staff
SOURCE:
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Kenmore stove top elements incorrectly heating
This may be a serious malfunction that you cannot attempt to fix on your own. You should bring an expert to talk about this. Chances may be, you will need to buy a new oven.
Feb 03, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
All 4 stove burner coils only work partially
You should check electricity coming to the range. On the back of the range you will find small square cover which cover power cord connections. Be very careful not be shot by electricity. It should be 240V(between red and black wire) and 120V (between red and white and also black and white wire). If it is than you have a shortage or some broken wire inside the stove.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 15, 2008 | Crosley CE35100AA Electric Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Dec 03, 2007 | Avanti ER24AW-1 Electric Kitchen Range
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Range
On your oven, look in your manual and you can calibrate the oven +/- 35 degrees.If it is out of the range of calibration then replace your oven sensor or themostat which ever one you have.On your fridge I would recheck your drain hose from both ends and puor boiling hot water down drain.The only 2 reasons why you would have water on bottom of fridge is 1 a water leak or cloged drain.good luck
May 25, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Avanti ER2001G Kitchen Range Logo
287 people viewed this question
Top Avanti Kitchen Ranges Experts
Shawn DuRee
ray gallant
Tom Chichester
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
