Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
