My sceptre TV doesnt turn on.
I think it may be the ac adapter.
Does anyone know how I can get an affordable ac adapter because I dont want to lose more money on a dud tv.
Delta Electronics
AC Adapter
Model # ADP - 180CB B
Thank You.
SOURCE: Looking for AC Adapter part no 21D0315
Hi! Are you still looking for that Adapter? I have it. If you are still intersted, please call me (Ray) at: (416) 752-7600 or (416) 633-1014. Or send me an email to: [email protected] I was about to post that AC (Part No.: 21D0315)on ebay! (We are in Toronto canad)
SOURCE: Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
SOURCE: ac adapter not recognizd.
You do not need a new laptop but i believe you need a new battery.RICHARDM69
SOURCE: i had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Testimonial: "thanks for the prompt response."
SOURCE: Green Light turns off when plugged in to the computer.
hi bro what u need to do is ... understand when u plug in the ac adapter the light on the ac adapter goes off and whne u unhoook it it comes on .. right there is a possible static charge in the mobo bcoz of which the ac current is nt able to flo on thru the wires to the motherboard .. what u can do is turn ur laptop off completely unhook the ac adpter and take off the battery as well press the power button for 15 sec press and hold it do this xcersice .. hook every thing up and try to charge the battery again it should work .....second possible thing can be may be the connectors on the mobo can be bad on the pin in the prong on the ac adpter must be twisted ,,, so check for that as well ...if still no go then either problem with the onboard power connector on mother board or the whole mother board power aseembly IE replace the mobo ....
cheers
