Most likely the thermostat is malfunctioning. What type of thermostat is it, and where is it located? CharlieMost likely the thermostat is malfunctioning. What type of thermostat is it, and where is it located? Charlie
You can't post conmments that contain an email address.
go into system setup activate freeze protection it will then ask you which features you want filter pump jet pumps make sure if you have water features and a autocover cover is open or those are not freeze protected
Also if you re-post question another question at Fixya with exact model number, I will probably see it.
Add a comment for more free help. Also take advantage of fixya expert assistance live. For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project. Fixya is always less expensive than a service call
It is hard to say with very little information in your problem. But if your having problems with a temp control of any kind and things run but not at the right time the first place to look is your temp sensor. this is a cilinder usually copper or stanless steel about half the size of a ciggeret and a little smaller around with two wires coming out of the end of it. If it reads water it will be inside a pipe and you just have to follow the wires. If it is a air sensor it will probally be just below the control box and ether hanging free or mounted to the wall, but it should be in the shade. If this is on a heater it will be found inside the unit usually on the main water header.
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
