Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
8200 inspiron wont start up
All light switch on when press power button, but then no fans etc, no but up etc ...
how can i solve the problem?
i tried to remove both ram and tested them - both works perfectly ... any help please?
  • 1 more comment
  • attardmarkan Sep 25, 2009
    no nothing, i got a new power supply(charger) which works ok as well ...
    what do you mean by the fuse in the plug?
  • attardmarkan Sep 26, 2009
    problem solved - trouble was comin from the video card - replaced the card with another extra one - and it worked . . .
    Problem Solver:
  • 16 Answers
Hi
Assuming the fuse in the plug hasnt blown...do the fan(s) in the power supply go round? If not then the power supply needs replacing.
Posted on Sep 25, 2009
  • Anonymous Sep 25, 2009
    Sounds like either the motherboard or the CPU is broken. CPU's dont usually break so check the motherboard for any blown capacitors.
6ya staff
SOURCE:
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
My dell inspiron 8200 laptop wont turn on all that happens is the leds that show power, battery etc come on for 2-3 seconds with a short whirring sound then it stops. I have tried the usual fixes of taking...
Have you tired using the electric cable instead of the battery? I presume you have. Does sound like it could be down to the power management in that case.
Nov 03, 2017 | Dell Inspiron 8200 Notebook
Computer won't turn on
Try a different power outlet, or plug directly into the wall.
This does sound like a bad power supply. You can get replacement power supplies just about everywhere computers are sold. It'll set you back about $50 and is relatively easy to install.
-=/ Daft Tech /=-
Oct 23, 2009 | Computers & Internet
Press power button. Green light turns on, fan
there is power buttom on the keyboard makes it wake up. try it
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 02, 2009 | Dell Inspiron 530s Desktop Computer...
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Laptop doesnt boot only power ligth comes out when press on buttom a ligth comes out but nothing on the screen i dont hear the fan keep going.
Maybe there are some problem in your start button (the button wire connect to mainboard is Loosening.
Please press the start button for about 3-4 seconds then see it would start. Always it may solve the problem, this happend to my inspiron 6400 too, after used for years the start button failure. It shows only power lamp lights green but the other light cant light red.
If no, maybe your must change a power supply, as the lower volt current cant start all the device.
May 15, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Mar 24, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Hang
There is not a reset button that model. The only other way to force restart it would be to unplug the computer from the outlet. This is not a recommended method but, it can be used a last resort if your computer is hanging.
Jan 09, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
132 people viewed this question
Ekse
Clive
Clive
Alun Cox
