Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Anonymous Posted on Sep 25, 2009
How open image ISO. files - Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Sep 25, 2009
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1159222
Points
10260
If you have NERO installed as the burning software then it automatically accepts it for burning on CD/DVD.
Alternatively Ultra ISO ver 6-8 is down-loadable at cnet or softpedia sites.
Else use uTorrent to download one. uTorrent is a free-ware...........sodeep
Testimonial: "Thank you for help."
Anonymous
Level 3:
  • Master 742 Answers
Anonymous
Master
Level 3:
Answers
742
Questions
0
Helped
193876
Points
2315
.ISO files are archived filed ready for burning to a CD or DVD discs using burning programs like Nero. Thus, Nero software can open and burn this .iso files to discs. Also, Winrar can open and extract the files in a .iso file archive. Download Nero to burn or Winrar to open them
Testimonial: "Thank you"
Nanny
Level 3:
Genius:
  • Microsoft Master 2,351 Answers
  • Posted on Mar 18, 2019
Nanny
Microsoft Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989287
Points
7262
You can try some applications to open the ISO files. For example, you could try Leawo Blu-ray Player to open ISO files. It not only can open DVD ISO files but also can open Blu-ray ISO files. https://www.leawo.org/tutorial/how-to-play-iso-files-on-windows.html?tw=#1389
2 Related Answers
Anonymous
  • 808 Answers
  • Posted on Sep 08, 2010
SOURCE: I can't open my windows xp in virtual box
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Anonymous
  • 143 Answers
  • Posted on Apr 21, 2011
SOURCE: i have 2 iso files for installing visual
If it asks for disk two, simply unmount disk 1 and then mount disk 2 through magic iso.
This would mimic removing disc one from the drive and inserting disk two. Of course this will only work if it installs while keeping windows running, and not in some restart mode for installation.
To check if this is the case, open the installer, and if you can still click on the start button and perhaps even launch your web browser, you know the method described above should work.
3answers
I cant seen to open this file en_office_professional_enterprise_edition_2003_united_states_x86_cd_489281.iso
its an image of a CD(orDVD)
there are 2 ways to use that file.
1: burn it to a CD (DVD)
2: run special software that allows ISOs to be run without burning it
called virtual clone drive, (free) v 5460. is what i run
tip
How to Convert .DMG to .ISO
Dmg file is the disc image file which is widely used by Mac systems. Most of Mac operating systems and applications are distributed in dmg files. On Windows PC, it is very convenient to manipulate dmg files with PowerISO. You can open dmg file, convert it to iso file, or burn it to a CD / DVD disc. To convert it to iso file, please follow the steps,
  • Run PowerISO.
  • Choose "Tools > Convert" Menu.
  • PowerISO shows Image Converter dialog.
  • Choose the source DMG file you want to convert.
  • Set the output file format to iso file.
  • Choose the output file name.
Convert DMG to ISO
tip
Mount CD DVD images - Ubuntu
1) Are there any programs for Ubuntu
(type: DAEMON Tools, Alcohol or Virtual Disk in Windows)
that will allow me to easily handle my: ISO, IMG, BIN, MDF,NRG , Image files?
2) I want easy to install such a program and immediately using it?
3) Gmount-iso and Furius ISO Mount provide everything we need.
We'll add it to Ubuntu in the following way:
(1.A)Gmount-iso:
1) System> Administration> Synaptic Package Manager
When you open it, you do Reload, Search and install:
gmountiso
2) Run Gmount-iso
Applications-> System Tools> Gmount-iso
(1.B) Furius ISO Mount:
furiusisomount
2) Run Furius ISO Mount
Applications-> System Tools> Furius ISO Mount
(1.C)You can start using your image files in a simple manner.
on Jan 13, 2010 • Computers & Internet
1helpful
Hi friends, How to convert dmg fil to iso file? I have mac os on dmg format how to create a installation dvd?
1.Double-click the DMG file to mount it.
2.Open Disk Utility, located in the Utilities folder within Applications.
3.Highlight the mounted disk, indented directly beneath the DMG file, in Disk Utility's sidebar.
4.Select "New Image" from the navigation toolbar.
5.Enter a name for the new image, select a place to save it and select "DVD/CD Master" from the Format drop-down menu. Select "OK" to start the process.
6.Open the folder containing the newly converted image file. It will have .cdr for its extension. Double-click the text to bring up the editing field to rename the file. Delete ".cdr" and add ".iso" and press "Enter." A warning will pop up, asking if you would like to keep the extension .cdr or use .iso. Select "Use .iso" and your DMG file is now an ISO file.
Thanks for using Fixya.Have a good day.
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
2answers
How do i open an iso File?
Hello Keaqanvermaa,
'.iso' is an image format. To open an iso file you need to install any one of the softwares called 'magic iso, ultra iso, power iso etc.
After insatlling any one of these software the .iso files icon changes into a recognized iso file format. You can now double click to open to and view whats its contents are, if its a software iso file you have to extract it first to a folder.
Good luck
please rate if this solution was helpful for you!
2answers
I can not record a ISO image in my GH22N550
Try using this software, Image Burn. It works for me every time. I gave up on all others. This program will burn ISO's to ISO's, it will burn ISO's to Boot Disks, it will make files into ISO's, it does it all.
Also, just to clear up the term, when you burn a ISO you are generally trying to make a bootable disk, you are not actually burning the ISO, but expanding and burning the files onto a CD or DVD that you will use to install something on another computer.
2helpful
2answers
I want to make my pendrive bootable to install window xp on my computer
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
1helpful
2answers
Nrg- files , how to open?
you can only open that file and make the icon file visible to your desktop by downloading cd or iso burner through nero, demon or alcohol. because .nrg files is a image extension file generate through software applications cd and iso image burners.
1helpful
Hi I can't open a .nrg extension file. pls help me
This is an NERO BURNING ROM File
here are several tools available to convert a .nrg data file into an ISO 9660 CD image.
  • Open Source command line tools include:
  • Shareware tools include:
    • PowerISO — converts from nrg to ISO as well as allows for browsing and extracting individual files from a nrg data file.
    • NRGtoISO — freeware. Converts a Nero NRG file (CD Image) to a standard ISO CD Image file.
    Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
