Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
Mark Phipps Posted on Sep 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag MFD2560HES - water flow restricted - noisy fridge
Our Maytage with bottom freezer and ice maker has a greatly diminished water flow from the port inside the fridge. The icemaker is producing what I call 'skeleton' ice cubes as they are the shape of an ice cube, but mostly hollow. Lots of nighttime noise from this (at least it is more noticeable when the house is quiet). I notice that when I open the freezer drawer, the noise stops and starts immediately upon closing it, so there must be an interlock. I've raised the sensor bar on the icemaker, but it still makes the noise once the drawer is closed.
Any ideas on this? I'd be okay with just making the noise stop for now.
Thanks,
Mark
  • 1 more comment
  • Mark Phipps Sep 25, 2009
    Okay, thank you. What if I want to explore this further myself? I unplugged the the ice maker and that stopped the noise. I am curious if the same pump or same solenoid provides water to both the ice maker and water dispenser within the fridge. It seems that the water must go to the ice maker first and because it is not filling, it constantly groans trying to get water into the freezing tray or mold (or whatever it is called). That would explain why my water dispenser in the fridge isn't working if the ice maker can't get any water. So what can I do myself? I managed to troubleshoot my dishwasher to a bad solenoid, but it was under warranty. This one will be on me. Thanks again.
  • mudpaws May 11, 2010
    my water dispenser would work sporadically and then stopped. The problem was that the freezer had iced up in the back and froze the water line. Once I took out all my food from the freezer., I melted the ice and now the water is flowing great!
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Sep 25, 2009
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1159222
Points
10260
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
  • Sudeep Chatterjee
    Sudeep Chatterjee Sep 25, 2009
    The answer to your last comment is "yes". The same vale fills both as required but if the solenoid has weakened then only a part of the valve will open up......................sodeep
  • Sudeep Chatterjee
    Sudeep Chatterjee Sep 28, 2009
    It is the same problem that you had while still under warranty and the solution is also the same as before.......................sodeep
Squeeking noise when using water service- poor flow. sometimes squeak when ice maker fills
Do you have filter in the fridge?This will cause this type of problem. Have you replaced it lately?
My maytag fridge isn't producing ice model #
see if the ice is frozen, there are three screws holding the ice maker in, two on top and one on bottom. The two top screws are teardrop screws and don't need to come all the way out. The bottom screw does need to come out. The electrical connection is a squeeze type and the unit should come out. Clean it out and re- insatll to see if that helps.
My fridge quit working.Freezer still works,cold air just not making it up top to the fridge.any ideas??
Most likely you have a defrost problem. The frost is building up on the evaporator coil causing a restriction to the flow of cold air from the freezer to the refrigerator.
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
2helpful
Hi, I have a Maytag (MFD2560HES) fridge. The Freezer is working but the fridge is not cooling. What could be the causes? Alton.
you need to check and make sure the evaporator fan is running in the freezer compartment while the unit is in the cooling mode if it is then check the damper in the top of the fridge and make sure it is opening all the way to allow the cold air in the fridge.if ti does not open it needs to replaced.
If the fan is not running it needs to be replaced also check for excessive ice build up in the freezer compartment that would also block the air flow
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
1helpful
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Maytag bottom freezer ice maker problem of ice removal
Usually low water pressure to the fridge will cause this problem. Not getting enough water to the ice maker will cause the cubes to be too small and get jammed easier. Check to see if you are using a self piercing saddle valve on your water line. If so change it to a drill type valve. This will increase water pressure to the fridge. New ice makers will not solve the problem.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
