either the tape or the recording head is dirty. use a new tape. if the lines are still there, get a head cleaner tape or use alcohol to clean the recording head.
IF YOU CANT GET THIS FIXED CAN I BUY IT FROM YOU AS I NEED A 8MM CAMERA TO CONVERT MY TAPES TO DVD AS MY OLD 8MM CAMCORDER WONT PLAY.OR DOES ANYONE HAVE ONE I COULD BUY CHEAP OR BORROW...IN MELBOURNE AUSTRALIA...CHEERS JB
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
The idler wheel (that only drives the tape in play or scan modes) is
slipping too much (very common problem). Try verify this by
putting the tape in play then immediately press the fast fwd or rewind
buttons to scan the tape. On older machines, the idlers used
rubber friction tires - on newer ones, a clutch. Either replace
the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
One of the units is not making good interchange in recording (CAMCORDER) or (PLAYBACK) DSR11 deck either buy or get a known good recording to isolate the bad unit. Camcorders are notorious for loss of interchange as the cassette compartment wears out the scissors jack elevator gets sloppy and changes the angle of attack on the drum and wellah a tape that only plays back in the camcorder.
Supreemwun, Canon support was of no help. They ****! To fix the problem this is what I figured out.
Before you start filming what you want record or just advance the tape 10 secs or so.
Record/ video whatever you planned.
Now when the thick grey lines come up on play back don't freak out.
Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
