I would verify that you are getting power to the amp and the remote wire is hot when you turn on the radio allowing the amp to turn on.
No sound from the speakers is because your audio signal is now comming from the PXA-H100, therefore you need to plug teh PXA-H100 back into the radio... or if you are using a factory amplifier with speaker level inputs, you would plug the PXA-H100 directly into the wiring harness to feed the speakers.
