If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood. Another trick is to spray your nails with WD-40 before you load them into the gun. Best regards, --W/D--
If it is the cordless Brad Nailer and will not fire nails anymore chances are the drive belt came off track. Internally those DeWalt cordless nailers operate much like a Baseball pitching machine. And when you fire a nail the drive belt pinches the driver blade which fires the nail. Here is the product documentation from DeWalt's website. http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=68728&typeId=16768&documentId=35981 The Drive belt is part #59. I have never opened one of these before so I can not tell you if it is a simple fix, I would open it up and peek around just a few screws on the top should open it. If you do not feel comfortable opening that unit yourself, I would take it to an Authorized DeWalt repair facility.
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either.
Sorry about the bad news but it looks like your going to have to spring for new nails
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
