You may try the steps below.
1.Remove the ink cartridges.
2.Reseat the printhead.
a. Lift the printhead release latch
b. Reseat the printhead, pushing firmly on the white label on the printhead (if provided) or the center of the printhead, until it clicks into place.
NOTE: You may also visit www.kodak.com/go/printheadsupport for demonstration on reintalling the printhead
3. After the printhead has been reseated, re-insert the ink cartridges into the printhead, make sure that the cartridges snap into place.
4. Close the access door.
5. wait for the printer to initialize.
If issue persists, printhead or the printer itself needs to be replaced. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
On my esp 3 I replaced new ink, still there was a low ink light. I took out the printhead and simply cleaned it carefully, Proplem solved
To order print cartridges:
}}--> }}-->Open the }}--> }}-->Lexmark
Solution Center
}}--> }}-->Click the Contact Information tab.
}}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print
cartridge.
How to reset Canon MX310
printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold
power button also. Hold both buttons
together for 5 secs.
3. Still holding the power button, release the
stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now
say 'Service Mode').
5. Wait until the power button lights steady
green, then press the stop/reset button three times with a 3 sec space between
each press. On the 3rd press the
indicator should turn steady orange.
6. Press the power button once, (the orange
light should go off).
7. Open the printer and remove both
cartridges. Wait for 10 seconds. Replace the cartridges and close
printer. Wait for 30 seconds.
8. Press the power button, and wait until
printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper,
then ask you to set the language.
10. The page counter is now reset! Enjoy.
