I have a problem with my xbox 360 i get no video or audio befor this happen all was working fine wondering if one of you folks have seen this
machine seems to boot up fine cannotverify becaue i cannot view video
can you point me right direction
thank you in advance
Hello and good afternoon my name i steve i have sort of the same issues, i bought my xbox 360 a year a go. The issue is i did use my box for a couple of days im married and my girls grandmother lives wit h us. when i turned it on the first time everything was fine till i started seeing the color of my game starting to blurr, then i tried turning it off when i did turn it off and turn it on there was no sound and no visuals then i turned it off and on again and i everything started working again then turned it off then it went back to no sound and no visuals.
can someone please help me.
Towel trick... worked for me....
You can very easily fix this one with the repair guide from http://www.xbox360-repair.com
Has it been flashed with xtreme firmware?
check the scart cable and make sure the switch is on the right setting (tv/hd)
when it was working did you put a game in and was you asked to update? if so you could have got a bad update.
if you have a hard drive detach it and then try turning it on.
if none of these work write a reply in this section and i'll get back to you.
please rate my solution and how it helped you
yeah but with the red lights flashing not without.
did u try to turn it on with the cd drive still out and disconnected?
only thing i can think of it being is a prob the the onboard graphics card.
have you still got warrenty?
might be worth giving xbox customer support and see what they say. they have been givin extra warrenty cover because of the amount of faulty console's
never been flashed with any sw other than original and i removed harddrive and had same result i even removed cd
drive .
have you read or heard of this before may i ask
thanks for trying no luck yet
the Xbox made a red flash and not sound and I can't see nothing
machine has never been modified or flashed as for warrenty none left
any other oodeas appreciated
thank you
while i was using my xbox the picture disappeard but i still had sound. wiggled connections but still nothing and tried on another tv. not sure what do do cause i don't want to lose all of my saved games on the harddrive
boots up fine but no audio or video
