Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
I got it fixed I figured out it wasnt charging right because my charger wasnt on correctly (the 2 different pieces) so i charged it now it works fine thanks anyways
I already fixed it my charger wasn't plugged in right so it wasn't charging and it was dead so i just stuck the charger in right and now it works ! Thanks anyways!
