Question about Franklin Industries Franklin Chef FIM200 Ice Machine
It has a water lik in a electrical piece that pumps the water around to be iced
    President:
  • 1,730 Answers
What is your question, be specific?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 03, 2009
6ya staff
SOURCE:
My refridgerator stopped producing ice and water. I replaced the ice maker, the water pump, and the circuit board behind he water and ice dispenser. It now dispenses water with no one around. Help?
What do you mean "with no one around"? It turns water on spontaneously? does it turn off again? Is it making ice and dispensing it correctly? Don't you love figuring this stuff out? :)
Jun 25, 2018 | Refrigerators
Ice maker leaks water into ice bin
Some things I have seen that causes this issue:
A. Plug not sealing properly in the bottom of the water reservoir
B. An issue dealing with the circulation pump. Maybe splashing water out of the reservoir while running due to crack in pump housing, especially around impeller, or hose that feeds water from recirculation pump to cold plate has a crack/split/loose connection.
Dec 23, 2013 | GE Monogram ZDI15C Automatic Icemaker
Kenmore 596.50692001 side by side stopped cooling. The fan is working, the compressor kicks on for less than a minute then kicks out. No cooling air flows. Water dispenser is working fine, but the water...
You most likely have a fried overload, it is the small white square shaped piece on the compressor, to tell if it is bad, remove it and smell it for electric burning smell, or if you shake it and it sounds like sand shaking around it is definately bad. costs around $25 to replace. You can purchas this at http://www.reliableparts.com/ using your model number.
Dec 01, 2010 | Kenmore Refrigerators
Water collects on bottom of side by side freezer forming ice. Water leaks from door.
The water leak is more then likly to be a condensation problem not helped by a bad seal around the door. This would need an enginneer really.
Aug 03, 2010 | Kenmore 44273 Side by Side Refrigerator
Should I replace the water pump? loud squeeking noise looks like discolored water sparyed around engine compartment
gm,water pumps are a part store super sale item ..if theres water coming out and its rust colored it most likly is bad very much so if it is making loud noises..pretty easy to replace..
May 19, 2010 | 2003 Chevrolet S-10
I get leakage around the lower door. Water pumps
Most likly you nailed it (almost)! Most dishwashers have a door seal and a lower door gasket. Most likly its the later of the two. You have to take the inner door off the outer door to get to this usually 4 or 6 screws
Mar 15, 2010 | Dishwashers
The machine is washing but the water will not drain after the wash cycle
if the washer spin's than you have a blockage,most likly it is in your water pump.take the discharge hose and lower it in a bucket,if no water come's out than most likly it is in the water pump.you will nead to remove as much water as you can by hand.also you will nead a pot or bowl to catch the water when you remove the water pump from the discharge hose and the large hose that go's from the outer tub and the water pump.with the pump off you should be able to look inside the pump and see the blockage and remove it.
Dec 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice tray wont flip
check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Dec 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice Maker not going through complete cycle
what kind of unit is it? there are several possibilities
May 07, 2008 | Refrigerators
Franklin Industries Franklin Chef FIM200 Ice Machine Logo
Top Franklin Industries Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
