SOURCE: My PC need driver, Motorola
in this link you get your driver
try it :
http://www.driverfiles.net/Modems/Motorola/SURFboard-Cable-Modem-SB5101/download/page,sh,30479,197,2,.html
SOURCE: Motorola surfboard sb5101 only gives me a
if you use the usb cable can only be sure your connection is 12Mbps, try to use lan cable that you certainly can. I also use the usb only 12Mbps, but can I use lan cable I can be more than that
SOURCE: problem connecting acer aspire 4736, motorola surfboard sb5101
2ways:
go to the msi website and use the live update
or you can get drivers from here
SOURCE: how to connect my motorola surfboard sb5101 cable
Hi turn both modem and PS3 off. Then connect the ethernet cable from the modem to the PS3 and then turn the PS3 first. Then after the PS3 is completely on, then turn the modem on so the PS3 will get the modem's IP adress.
I recommend you get a router and connect it to the modem and the PS3 to the router. It's way better. I hope this helps.
