I have a 32inch GE TV and it doesn't turn on. when you press power either on the remote or the actual tv set, it makes the noise to indicate that it's turning on but no screen comes light. also, it repeats this process 3 times every single time you press the power button. is there a way to fix this or should i consider getting a new tv. thanks
Programming a GE/Jasco Universal Remote Control is simple, requires only a few simple steps. You need to know the code of device you are programming into the remote. See the GE remote control codes page for3 digit or 4 digit GE remotes.
How to enter codes manually:
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
The SLEEP feature
Some GE remote controls like the RM94902, RM94904 or RM94905 have a handy "sleep feature" enabling you to turn off your TV after a preprogrammed time interval of 1 to 99 minutes. To use the sleep feature follow these steps:
1: Press and hold the "SLEEP" button until the indicator light turns on.
2: Enter the time interval in minutes using the numerical keypad. (for minutes from 1 to 9 press 0 before the actual number).
3: Leave the remote aimed at the television set.
To turn off the sleep feature, press and hold "SLEEP" until the indicator light blinks or press the "POWER" button to turn off the TV.
