Hi, whenever I turn on my camera it makes a weird noise, and the screen is real blurry. I took some pics two weeks ago and it worked perfectly fine, and today it won't. Thanks in advance for any help
The lens can be removed, and the gears checked out for debris, and re-aligned/cleaned. Google my user ID if you want more info, and you'll find me.The lens can be removed, and the gears checked out for debris, and re-aligned/cleaned. Google my user ID if you want more info, and you'll find me.
You can't post conmments that contain an email address.
If it's making noise when turned on you are experiencing trouble with the lens. If you send it into repairs they can fix that. Give them a call at 800-706-2534 option 2.
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Ok, first try resetting the camera. In the picture taking mode press menu, go over to setup, go up to reset, press right arrow, make sure reset is highlighted and then press set. If that doesn't work there is nothing to do but send it in. It may be from any form of damage sustained to the lens. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
is there anyway to fix it?
