The printer has two cables namely the data cable and power cable.
The data cable connects the computer to the printer and the power cable connects the power outlet to the printer.
If the power cable is removed then connect the power cable to its respective port depending upon the type of printer.
The data cable on the computer end connects to the USB which looks like this.
The other end depends upon the type of printer
It might look like any of these three
The first one and the third one is used for single computers and the middle is used for connecting the printer to a network.
Look for ports similar to these and connect the data cable to the ports. Then the printer is setup.
Following this the software for the printer needs to be installed which is provided with the printer.
This completes the installation of the printer.
Kindly comment.
I will explain you.read it as follows. 1)In the back of the printer there are two connection.one is for power to the printer and one is for the connection between the computer and printer.if the printer is having power that means the power wire is connected.if no power then power wire came out.you can just see to back of the printer.you will see two sockets.1 for the power and other for communication with pc.just slowly insert the wire to the back.as both the sockets in which wire is to be inserted will look bit different.so you will easily be able to see that which wire goes were. its not at all dangerous.and not risky.just keep all the main outlet off before connecting wire. --------------- this will help.please do rate the solution.thank you for using fixya.keep updated.thanks.
How do I go about TALKING to an expert?
