ASUS P5W DH Deluxe Motherboard Logo
Posted on Dec 15, 2007
CPU errors I have already assembled everything together. It's an asus motherboard and a pentium processor, Intel. The problem is that the bios posts an error that the fan is not working and it worked before plus the processor says that there is cpu uload error. What should I do?
paul shaw
Level 1:
  • Contributor 37 Answers
  • Posted on Dec 15, 2007
paul shaw
Contributor
Level 1:
Answers
37
Questions
Helped
15681
Points
61
I have had this problem myself with asus board before .I flashed an update to bios and it sorted it out u could try this
by the way r u trying to overclock? because wrong memmory settings can cause this to
Asus motherboard model P5VDC-X compatible processor
ASUS P5VDC-X supports Intel Celeron, Intel Pentium 4, Intel Pentium D Processors. The motherboard is capable of supporting the Intel LGA775 Pentium 4, the dual-core CPU, as well as compatibility of either 64- or 32-bit architecture.
Please refer to Product Manual for ASUS P5VDC-X Motherboard for further details (if required)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
What Cpu fit a p5kpl-c and the best to buy.
This is older type of motherboard, made by Asus and supporting Intel Pentium 4, 775pin processor (LGA775). It will support DDR2 to the value of 4GB, it will support 64bit operating system. it have single PATA port, SATA is present but no RAID configuration.
This motherboard requires PCI video card, there is noAGP port and no build in graphics. System is based on Intel G31 Express chipset.
Theoreticaly this motherboard should accept all Intel Pentium for 775 pin processors, albeit early production may need BIOS flush with latest BIOS.
List of processors accepted:
Intel Pentium 4, Intel Pentium D, Intel Pentium Core 2 Duo, Intel Pentium Core 2 Extreme and Intel Pentium Core 2 Quad.
If you need more information or drivers for this particular board, please visit this site adn select exact model:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Do not hesitate to leave feedback how did you go with this advice :-)
1helpful
3answers
Sir can i change my processor to dual core using this asus p5v800-mx?
Dear sir,
Deffinately This Mother Board supports Dual core 2ghz-2.8Ghz And Pentium D 3GhzProcessors.You can Upgrade your PC.
P5V800MX motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Enjoy the extraordinary CPU power from the latest dual-core CPU.
2answers
What are the compatible processor for asus p5p800 mx
Asus P5P800-MX Motherboard Features
64bit CPU support
64-bit computing, the next generation technology to replace current 32-bit architecture, delivers advanced system performance, faster memory access and increased productivity. This motherboard provides excellent compatibility and flexibility by supporting either 64-bit or 32-bit architecture.
Intel EM64T
Intel EM64T (Intel Extended Memory 64 Technology) allows processors to run newly written 64-bit code and to access larger amounts of memory, which delivers exceptional graphic performance and higher data processing speed. Digital media applications can take advantage of Intel EM64T in high quality video and audio processing as well as 3D rendering.
Intel EIST
Intel EIST (Enhanced Intel SpeedStep technology) automatically adjusts Intel 64-bit processor voltage and core frequency according to system performance demand, establishing a self-managed, lower-power consumption, less heat and quieter environment. Combined Intel EIST and ASUS Q-fan technology (adjusts fan speeds according to system loading), this motherboard provides excellently quiet, cool and efficient platform for Intel lovers.
Intel 865GV chipset
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks.
Intel LGA775 Pentium 4 CPU
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
3answers
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
1helpful
2answers
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
1helpful
Cannot use intel pentium processor
you can only use socket 370 (Intel Celeron/Intel Pentium III) processors on that motherboard. Your maximum cpu speed is set by the bios.
3answers
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Urgent
are you sure that you have the same zif socket types either a intel celeron or an intel pentium, they are different socket types, but if theres nothing wrong with your other cpu your not going to see any difference in speed, upgrade your memory, but obviously if your other cpu has failed check the socket types and then reset your bios on the motherboard shorting terminals.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
