Sony Ericsson W850i Cellular Phone Logo
Posted on Dec 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MMS settings for W850i
I have an unlocked SE W850i, and a Cingular/ATT sim card, and i am trying to get the correct MMS settings so i can send and receive picture messages. ive found some sites online that have the settings, however they are shown in a format and menus that my phone does not have so i do not know where to input these settings. i have also gone to the SE site and had then send the WAP setup and the MMS setup to my phone, but when i go to send or open my picture messages, i keep getting a 'download communication error'. any help or insight to this, ive tried the Cingular tech support, but the phone is apparently a UK release and they do not have it, but i was told by someone else that as long as i have the correct settings and the proper APN it wont matter.
  • 1 more comment
  • Hellbells Dec 30, 2007
    I get the same download failed communication error please try again later when i recieve picture messages
  • angbye Feb 15, 2008
    not receiving downloads from mms
  • gwen2 Feb 27, 2008
    need to set up a mms profile so i can send picture messaging
A
Anonymous
Yes i do. i had the settings sent straigh from the SE corp page. and i also verified them with Cingular. and my phone will still not allow me to send or receive MMS messages. tells me there was a communication error and to check the settings, but the internet on my phone works perfect, so i am unsure of what to do with the settings
Damen Wong
Level 3:
President:
  • Master 1,950 Answers
  • Posted on Dec 16, 2007
Damen Wong
Master
Level 3:
President:
Answers
1950
Questions
0
Helped
1027614
Points
5739
Do you have the MMS message server configured properly?
1helpful
Mms setting for att
Internet settings for AT&T
Title:
Att
Bearer: GPRS
Auth: PAP
User: [email protected] (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
To get google and all your other java web access make sure that this is the only profile you have in the Access Point. This will default as your java web setting & streaming setting. So you can now stream youtube & use Opera Mini 4.
Best regard:
Henk®Muskita ©2009.
2answers
I68 no MMS
hi there I have the same exact phone these are the exact settings I have on my phone.
first you will need to create your data account.
select services
select data account
select GPRS
select first entry
edit account name to ATT
press options then press done/ok
edit APN to wap.cingular
edit username to [email protected] (UPPERCASE)
EDIT PASSWORD TO CINGULAR1 (UPPERCASE)
AUTH TYPE TO SECURE THEN SELECT DONE AND SAVE.
NOW TO SETUP MMS SETTINGS
select mms then select mms settings
choose edit server profile or edit profile
select the sim card you are using
click edit profile
rename profile to ATT MMS
press options press ok
edit homepage to http://mmsc.cingular.com
edit data account and select ATT
select http and choose http ip address is 066.209.011.032 and the port is 8080
username is [email protected]
PASSWORD IS CINGULAR1
SELECT SAVE AND YOU ARE ALL SET, ENJOY YOUR PHONE.
1helpful
2answers
Phone wont send or receive picture messages
call ATT, mine did this same problem, and it for some reason got kicked off in the ATT system that i didnt have the correct messaging plan anymore. it sounds odd, but it fixed mine. good luck!
you may try a master reset after backing up to your PC if that doesnt work.
Hope this helps! pls dont forget to rate the solution!
Nokia 6085 on att won't send or receive mms/multimedia messages
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: [email protected]
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
at&t apn settings 4Gdetails: If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
Can't send or receive MMS messages
I work in TSD for ATT , and from multiple cases like this , customer do not know that ATT requires that all PDA phones do require a PDA data package , without this you will not be allowed to send or receive MMS messages.
6helpful
3answers
Side kick slide unlock code please
Follow the instructions below:
go to phone messaging
then picture messaging
press jump button,
go to settings,
go to accounts,
press jump button again, (or press jump+n)
select new account,
insert these settings in the feilds provided
apn: wap.cingular
proxy blank
port blank
username:[email protected]
password:CINGULAR1
server blank
mmsc: http://mmsc.cingular.com
mms proxy: wireless.cingular.com
mms port: 80
:D
enjoy picture messaging on the sidekick slide with att :D
I have a t-mobile phone but a cingular smart card...
If the Cingular SIM card won't operate the T-mobile phone now? You'll have to have the phone "Unlocked" for it to work with your ATT/Cingular SIM Card. Some local Cell Phone Shops may provide unlocking services for a nominal fee (you'll have to call around and ask), or you can send it out to be unlocked as this service can be found by searching online, as you can see here: http://www.google.com/search?hl=en&q=cell+phone+unlocking&btnG=Google+Search
Picture messaging
what kind of sim card are you using in it now? in order to receive send pictures (other than bluetooth) you need a sim card. and if you have an att sim card in it and it is not letting you send receive picture mail, your internet is off. (we call this WAP in the industry). The easy fix:
Call ATT if you are using it on the ATT network and tell them to have the internet pay per use turned on. Then you will be able to receive MMS messages.
MMS settings
yes .....you should call you mobile provider and get the correct MMS settings for you.
Changing browser from t-mobile to att/cingular
check att/cingular to configure your GPRS/MMS on your phone.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
