The zoom button lever, which surroundsd the shutter button, is stuck. One day it was perfect, and the next day it was stuck. Any suggestions? The camera is out of warranty as I've had it over 1 year. There's nothing caught in it, no dirt or dust that I can see, and the camera was not dropped. Any suggestions for cleaning or loosening that rotating zoom button lever?
This worked! I was very leery about applying wd40 to my camera, of course, so I actually was able to work some dental floss around the outside of the zoom lever. I sprayed wd40 on my fingers and applied it to the floss, and then used the floss to get underneath the zoom lever.
Many thanks! JaneThis worked! I was very leery about applying wd40 to my camera, of course, so I actually was able to work some dental floss around the outside of the zoom lever. I sprayed wd40 on my fingers and applied it to the floss, and then used the floss to get underneath the zoom lever.
Many thanks!
Jane
No, it didn't display any error messages at all; that was the first thing I'd checked for.No, it didn't display any error messages at all; that was the first thing I'd checked for.
AnonymousMar 13, 2014
shutter button with built-in zoom lever has come out of socket. need to put back in. How?shutter button with built-in zoom lever has come out of socket. need to put back in. How?
You can't post conmments that contain an email address.
You can try adding a few drops of wd40//Please do not spray directly on there.Try to use a medicine dropper instead and drop a couple of drops directly on button...
drop the drops around the lever so that wd40 will penetrate inside where button attaches so that it will release button..goodluck..please let me knowdrop the drops around the lever so that wd40 will penetrate inside where button attaches so that it will release button..goodluck..please let me know
im glad I was able to help you..Please accept my solution by using the accept link..thanksim glad I was able to help you..Please accept my solution by using the accept link..thanks
It's near the shutter button where you press to take a photo. It slides each way. If it's broken and you need to have it serviced, this is the place for the Canon's: www.CamerasAndParts.com They are the best if you need a repair for one of the Canon models.
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
Solution:
Procedure for setting Digital Zoom PowerShot A520
Digital Zoom
When
the LCD monitor is on, images can be zoomed with the combined optical
and digital zoom functions as follows (figures are approximate):
5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times
1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for or .
3. In the [ (Rec.)] menu, select (Digital Zoom).
4. Select [On] using the or button and press the <MENU> button.
5. Press the zoom lever toward and hold it.
The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward again to further zoom the image digitally.
Press the lever toward to zoom back out.
6. Shoot the image.
Shooting procedures are the same as for the mode.
The digital zoom cannot be used when the LCD monitor is off.
images become coarser the more they are digitally zoomed.
Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
Auto Mode
In this mode, all you have to do is press the shutter button and let the camera do everything else.
1. Turn the camera on.
2. Turn the shooting mode dial to .
3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
Two
beeps will sound when the camera has finished metering, and the
indicator will light green or orange. If the LCD monitor is on, the AF
frame will appear green.
The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
6. Press the shutter button all the way.
You will hear the sound of the shutter when the shutter activates.
The picture appears for two seconds on the LCD monitor, if it is on.
The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Many thanks!
Jane
