Question about E-Machines eMachines Desktop PC
Installing radeon s9259 graphics card on a emachine t5010
Cant seem to get the computer to reconize the new graphics card. disabled current graphics and changed in the bios to ex. pci. please shed some insight. thanks
    Sergeant:
  • 239 Answers
Did you try to after you install the card to go into the control panel and install new hardware in the add new hardware. If I understand you, when you plug the monitor into the new video card it does not turn the monitor on, Even after you install the card and reboot your pc with the monitor plugged into the new device it don't come on, Make sure the old one is disabed in the device manager and it should work, If Not I need somemore information, You should not have to have changed it in the bios, you may want to change that back to the way it was, the radeon is compatible with the emachine and should work just by installing and plugging into it,Try that see what happens.Hope it helps Happy Holidays Just write back here if that don't work and I 'll figure it out for you,
Posted on Dec 15, 2007
6ya staff
SOURCE:
I actually have the 512mb graphics card but my question is how do i install graphics drivers when the installation disc wont even do a complete install?
unplug power cod, open computer Cabinet panel, remove cmos for 2 min and reinsert cmos,
wipe graphics card socket, reinsert graphics card, TURN on computer, press f2 to load default setting
you do not need to disable onboard graphics. in bios, some bios default configure your graphics card to primary
hope will help you
Apr 29, 2014 | ASUS Video Card ATI RADEON HD 5450, (1 GB)...
Disable onboard video card on dx4870 ub318
enter your Bios then Advanced settings there should be an option to turn of onboard graphics or switch to pci..
Dec 27, 2012 | Gateway Computers & Internet
My integrated motherboard graphic card is damaged and i am installing a new graphic card but i need to disable any built-in graphic capabilities on the motherboard. can u please help?
Enter the bios and disable the onboard video card. If that is not an option, then there should be a setting for the video to boot to AGP or PCI. Change to PCI.
Jun 20, 2011 | Computers & Internet
HOW TOI DISABLE ONBOARD GRAFIC AND INSTALL NVIDIA GRAFIC CARD
fit the graphic card to your pci-e port of the mother board
on bootup press F2 to edit the CMOS/BIOS options
and disable the VGA graphics or noboard graphics there
ENABLE PCIE graphics.
save the settings
boot to windows
upon boot install new drivers for PCI-E card
restart the pc
Mar 04, 2011 | Asrock PV530 - 1.8 GHz processor - VX900 -...
My computer using windows 7 cant detect my new video card, (evga geforce 9500 gt, when i turn on my computer i tried connecting vga with the dvi adaptor to my graphics card but that doesnt work, i saw...
Hi drago,
You can find your drivers here:
http://www.evga.com/support/drivers/
Download the drivers you need, and install them manually in the Device Manager.
In Windows 7, goto the Device Manager (click on Start, right click on My Computer, left click on Properties, click on Device Manager) Look for your video cards, click on the + to see which ones are installed.
Once you have the new drivers installed, you may have to uninstall the integrated graphics drivers to force Window to use the new card.
Hope that helps
Dec 25, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
I have a dell dimension 4400 and the original graphics card thats came with it but yesterday i when too turn on my computer and the screen is not picking up and image from the CPU is there anything i can...
OK, I am curious how are you going to install a new graphics card without installing a new graphics card? "picking up and image from the CPU is there anything i can do to install a new PCI graphics card with out having too install the new graphics card"
You can install a different graphics card in the computer assuming you have an open expansion slot. If the Current Graphics card is actually installed in the AGP slot open the Main CPU unit and remove it then install the new card. If when you started the computer you saw anything on the screen, the DELL logo or Bios setup, the problem most likely is not the graphics card being bad but possibly that the settings in windows some how changed and it is set to something it can't support or the monitor has gone out. If it is the graphics card and it is built onto the motherboard you will have to install the new card and when the computer starts enter the Bios to change the BIOS settings to disable the on board card or it will give you problems with conflicting resources. Most graphics cards use the same resources so two cards in the same computer will conflict with each other and neither will work. I would test with a different monitor before replacing the graphics card.
Dec 13, 2010 | Dell GeForce2 MX, (32 MB) Graphic Card
I got the this pny geforce 8400 gs pci card but it sends nosignal
You need to install the driver that came with the card. If you don't have it you can download it from the site. Also (for experienced users), check your BIOS setting to see if it has an option to select between the integrated graphics card your other one.
Apr 06, 2010 | PNY GeForce 8400 GS, PCI Video Card
Want to disable onboard graphics to install and use pci vga card
During the initial boot sequence (as soon as you turn your PC on), try pressing <DEL> button (or F2 or F10 - you will see info on the bottom of the screen stating something like "Press _____ (del, F2, F10) to go to Setup..."
This will take you to BIOS, main setup panel for your PC.
There you can find and option for switching your main GFX card.
Options will be something like: onboard, pci, agp. You should choose
PCI.
Try doing this after you insert your new PCI gfx in your computer.
Good luck,
Milan
Jun 01, 2009 | EliteGroup P4VMM2 Motherboard
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Motherboard - disable onboard graphics
1. open your cabinet.
2. remove the battery form the motherboard.
3. wait 15 seconds and then replace the battery again.
4. connect your screen to the pci ex card.
now it should work.
CS
May 15, 2008 | Gateway GT5220 PC Desktop
E-Machines eMachines Desktop PC Logo
232 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
