Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I am sharing the printer on my homenetwork. The printer is connected directly to my destop via USB. I can add the shared printer to my laptop and use it. However, when I resart my laptop the printer is gone and when I try to add it again I get the following: "Windows can not connect to the printer. Make sure that you have typed the name correctly, and that the printer is connected to the network."
  • 3 more comments
  • awadams_91 Sep 24, 2009
    The advice I recieved connects the printer locally, it doesn't connect it over the network.
    Again, my problem is that I can not use a shared printer on my laptop over my homenetwork. I added the shared printer once to my laptop; however, when I restarted the laptop the printer was gone. And then when I tried to add it again I got the following: "Windows could not connect to the printer. Make sure it is spelled right and it is connected to the network."
  • awadams_91 Sep 25, 2009
    Hi Nina,
    My desk top has vista home premium (32 bit) and my laptop has vista home premium (64 bit). Desktop is a gateway GT-5630A and my laptop is a gateway MD-2614U.
    Yes, I have installed the printer directly to the laptop via USB to make sure the 64 bit drivers are installed and that the printer works. I use to, use a samsung ML-2010 lazer printer before the Kodak and I never had any problems with that printer working over my home network. I didn't have any problems with networking the printers until I got the Kodak printer. Nonetheless, both printers did work over the network for sometime.... about a month.
    I am not sure if a windows update caused the problem, or it is the Kodak printer. For that reason, I have deleted both printers and used Kodak's cleaning tool and reinstalled the software. Like I have stated before, I can network the laptop after that process and the printer works. But, when I shut the laptop down and then restart it, the printer is gone. Then upon re-addeding the printer I get the message, "Windows can not connect to the printer. Make sure the name is typed correctly, and the printer is connected to the network."
    Thanks,
    Tony
    Ok, people.
    I have done the obivious.
  • awadams_91 Sep 26, 2009
    Sorry for being snippy. I am not running service pac 3.
    I mean windows udate. It has been awhile since the update and the loss of the printer; the restore point is no longer available.
    President:
  • 3,278 Answers
What operating system and what laptop make and model ?
Posted on Sep 24, 2009
  • 1 more comment
  • NinaE Sep 25, 2009
    Hi, Tony.
    Be certain that you have the latest Kodak software and firmware:
    http://www.kodak.com/global/mul/service/...
    Also, try uninstalling your anti-virus software to see if it interferes.
    So, all was working fine until the Windows upgrade ?? If so, try testing with System Restore (select the date before the upgrade, if you are not familiar with System Restore) to see if the problem is resolved on the short term.
    Hi, Tony.
    Sorry if I'm stating the obvious to you. We never know what level our customers are and usually take them through which may seem like basics to you.
    But, when you said the problem may have occurred after a Windows upgrade, I wondered if the problem occurred after installing SP3 ...
  • NinaE Sep 28, 2009
    Try removing and reinstalling the printer to your network.
    If still a problem and you are using a switch on your network, the switch could be causing problems. Replace the switch.
  • 453 Answers
- Start - Control Panel - Printers
- Add a printer
- Add a local printer
- Use an existing port
- From the drop-down box, select "(printer name)(client side rendering provider)"
- Select (or install) your printer driver.
- Give the printer a name.
This should work.
else kindly comment.
Posted on Sep 23, 2009
How to Share a EPSON Printer among Different Computers?
Well, a little more info regarding the printer would be great but here is the basics. If it is networked (plugged in via ethernet cable to your router or switch) you should be able to add it via IP the same way you normally would through your computers control panel/devices and printers. If it is directly connected to a computer via a usb cable you can still share it on the network you are on by right clicking on the printers icon, going to properties, then the sharing tab, then click on share this printer. If you need more help, be sure to download the 6ya app from the apple store or google play store and give me or someone else a call.
Aug 03, 2018 | Epson Office Equipment & Supplies
I purchase hp laser m1005, can i convert to wireless
Not that I am aware of , but to print from it wirelessly can be done if you have a home network. If you have a Destop computer ,for instance, you could connect via a printer cable to the desktop and share the printer on your home network you set up. on your laptop just add a printer and it will work wirelessly as a network printer.
Nov 09, 2012 | HP LaserJet M1005 Printer
How to get a print by using wireless function
Share Your Printer on a Home Network· Navigate to the Control Panel and click on"Printers and Other Hardware."
· Click the printer you want to share in thePrinters and Faxes folder. Click on "Share this Printer" in the TasksPane or right-click on the printer and select "Properties."
· Open the Sharing tab and click on "Sharethis Printer." Enter the name of the shared printer and click"OK."
· Use the shared printer with any computer on thenetwork by navigating to Control Panel > Printer and Other Hardware.
· Click "Add a Printer" and browse forthe network printer you just shared.
Connect the Printer Directly to the Network.· Plug the printer directly into the network hubor router.
· Follow the instructions for setting up theprinter for networking provided by the printer manufacturer.
· Click "Add a Printer" and browse forthe network printer.
Dec 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Dell a920 network problem
I will assume you have the Printer connected directly to a PC via the USB printer cable on our network.
a. Start - Run - Control - Ok
b. Open 'Printers and Faxes"
c. Open "Dell A920"
d. Print "Test Page" to assure the printer is working and connected.
e. With the "Dell A920" properties open - find the tab for Sharing.
f. Now select Share the Printer and name it.
At each Workstation you will need do steps a-b, and add the printer. Select browse network when adding the printer and find the Workstation with the shared printer.
If your Firewall on each Workstation is blocking "Print and File Share" you will need to change the settings to allow this procedure through.
Here is a link that may help further.
http://www.smartcomputing.com/Editorial/article.asp?article=articles/webonly/techsupport/73w10/73w10.asp&guid=
Hope this helps.......
God Bless.......
Jul 28, 2009 | Dell A920 InkJet Printer
Wireless Laptop and Wired Desktop cannot communicate
Simply printer sharing should be enabled on both computers as well as file sharing.
Helpful Links
Printer Sharing
Jun 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has...
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Trying to connect share printer w/Vista
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
May 28, 2008 | Linksys 4-Port CPU Switch 843734000836
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
93 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
