A video tape has become stuck in my Mitsubishi VCR
A video tape has become stuck in my Mitsubishi HS-M58 VCR. The machine powers up OK, but then just powers down itself. It will not eject, play or FF/RW...note the machine was perfect before insertion of this dubious tape. Thanks
  • 32 Answers
Hi, Suggest call a local tv repair shop. Thanks.
Posted on Sep 22, 2009
6ya staff
SOURCE:
Hs-u54 vcr has snow on video
Head amplifier circuit/module could be the problem in your case. You could also check the power supply to see if any electrolytic caps are out of tolerance or have changed value and replace them if necessary.
Here are a couple of examples of similar VCR issues I've had; some years ago, I had a Panasonic NV-F70A, with snowy video playback, and, after a lot of investigation and exhaustive testing it turned out to be the video head amplifier module that was the problem (not the heads themselves which were new) - replacing the plug-in aluminium-cased module fixed it and restored the video picture as well as the stereo audio output and flying head erase. Power supply was OK and the whole VCR good to go.
With another Panasonic (NV-J11A), it was several out of tolerance electrolytic capacitors in the power supply (another metal-cased plug-in module) that caused the snow on screen, erratic tape counter, and slightly wobbly audio. Head amp was OK in this one. I replaced every electrolytic in the PSU - and after plugging the module back in and turning the VCR on, the playback picture and tape counter were soon restored to normal - after some soak-testing, the machine went home.
You may not need to do anything to or with your machine's power supply at all but it doesn't hurt to check anyway so that you can rule it out as a possible problem source.
Dec 20, 2017 | Mitsubishi HS-U540 VHS VCR
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
Dec 23, 2010 | Mitsubishi HS-U448 VCR
Mitsubishi HS-U57 vcr front display gets very dim!
Your front display is worn out, it has gotten gassy. Therefore the luminance level is low & the part is no longer available.
Nov 07, 2009 | Mitsubishi HS-U577 VCR
Error code E4 on Mitsubishi HS-U576 VCR. Machine is eating tapes.
Hi, The error E4 means Reel Lock Detection.
Thanks! mannu_rakesh
Sep 02, 2009 | Mitsubishi HS-U576 VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Can't get a picture on TV screen
I think the tape is blank. I mean not recorded.
Oct 24, 2017 | Mitsubishi HS-U545 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
Feb 28, 2008 | Mitsubishi HS-U447 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
