Computers & Internet Logo
Posted on Sep 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't install flash player 8 or up on my pc. I have windows vista and I tried to install other programs and it tells me i need flash player 8 or up. What do I do?
Anonymous
Level 2:
  • Expert 178 Answers
  • Posted on Sep 28, 2009
Anonymous
Expert
Level 2:
Answers
178
Questions
0
Helped
32860
Points
358
During installation of flash player u nedd to close all windows...(all programs that are running..) first install any other vesion of flash player that is below 8....
plz vote me if i solve ur problem
4helpful
2answers
2helpful
I tried re-installing flash player and all the settings are in order, but farmville keeps giving a black screen...?
Try this
1. Uninstall Flash Player using the Flash Player Uninstaller - click here
2. Download the reset_fp10.zip file and extract the reset_fp10.cmd file to the directory C:\ - click here
3. Download and install the Subinacl tool to the C:\ drive (By default it installs in C:\Program Files\Windows Resource Kits\Tools\ but if you install it in that location it will not recognize the subinacl program even if the reset_fp10.cmd is in the same location)- click here
4. *Important: Be sure that both the subinacl.exe and reset_fp10.cmd files are in the same location.
5.
In Windows Vista and Windows 7, launch command prompt (Run as Administrator) and go to C:\. Type "reset_fp10.cmd".A command window will open, and SubInACL will run.
6.
Do not use the machine while SubInACL is running.
7.
After SubInACL finishes, you will see a prompt "Press any key to continue".
8.
Download Flash Player 9 Activex - click here
9. Install the Flash Player- click here / or download from www.adobe.com/go/getflashplayer
These procedures worked on my friend's PC, hope asme goes to yours. Goodluck!
1helpful
My widows is VISTA. I am trying to download ADOBE FLASH PLAYER 10. But it is not working now. So, tell me how i can download it. Shihab
Hi.
Here is what I found on the network regarding your problem.
It might help you.
Here's the scenario: you download the latest and greatest version of the Adobe Flash Player. After it finishes installing, you go to a site featuring Flash content and are greeted with a message notifying you that you need to install Flash Player, but didn't you just do that? To properly update your Flash Player, you need to run the installation as Administrator. Follow these steps to properly install Adobe Flash Player:
For Vista (32 bit):
1. Open Computer.
2. Navigate to C:\Windows\System32\.
3. Scroll down and open the Macromed directory.
4. Open the Flash directory.
5. Right-click FlashUtil9b.
6. Select Run as Administrator.
7. When the UAC prompt appears, select Continue.
8. Follow the Flash Player installation wizard.
For Vista (64 bit):
1. Open Computer.
2. Navigate to C:\Windows\SysWOW64\.
Once the wizard completes, Flash Player has been properly installed and will now function properly.
2helpful
How to download adobe flash for windw vista free
Download the latest and greatest version of the Adobe Flash Player. After it finishes installing, you go to a site featuring Flash content and are greeted with a message notifying you that you need to install Flash Player, but didn't you just do that? To properly update your Flash Player, you need to run the installation as Administrator. Follow these steps to properly install Adobe Flash Player:
For Vista (32 bit):
1. Open Computer.
For Vista (64 bit):
1. Open Computer.
Thank you for using FixYa
Don't forget to vote thanks!!
1helpful
Some games won't play on my computer (xp pro) and it says I need flash player 8 or higher but I have flash player version 10 installed? I have radeon 9550 drivers installed. Am I mising others I might...
Try to uninstall the Adobe Flash Player Active X and Plug in and then reinstall it as there could be traces of previous versions in the computer which are interfering and making it difficult for the browsers to properly display videos on your computer. You can do this from the computer user settings and manipulating the "Add/Remove" programs list.
-- Try to use Flash Player 9 is your Flash Player 10 is not working fine. You can simply download it from the Adobe web site.
-- Update the drivers, the link is given below which would ask you to download the file through internet and run it on your computer.
-- The problem behind the Shockwave Flash crash could be your sound drivers. Follow these steps:
1) Open Device Manager 2) Look for the sound-card device 3) Note down the name for that device 4) Just uninstall the it. 5) After uninstalling restart your machine. 6) Your Windows 7 or Windows Vista would automatically download and reinstall the sound driver. You can also do it manually through approaching the sound card company's web site.
-- Fix your Windows Registry which is a highly recommended thing you should do to find a quick and reliable fix for common PC errors and crashes.use registry cleaner reg in out
I have tried many times to download Adobe flash player onto my computer, My programs tells me it is downloaded, but, when I try to watch you tube videos I'm being told I need to download Flash player. I'm...
you need to download the latest flash player. but sometime it says you need flash player to watch but if you wait a minute that disappears. and video can then be watched here is link for latest flash player. good idea to download the shockwave player as well. check if its for xp,vista or windows 7.
Adobe - Downloads
Cannot download Adobe Flash Player. Have downloaded different versions. The download appears on the Control Panel--->Programs----> uninstall/change but is not usable.
Use "Add/Remove Programs" to uninstall Adobe Flash Player.
Close all Internet Explorer windows.
Start Internet Explorer.
Access: http://www.adobe.com/software/flash/about/
and the latest version of Adobe Flash Player will get installed.
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0) Timestamp: Sat, 30...
It would have been added to black-listed or restricted website in Internet Explorer Content Advisor by some user in your computer.
· Some malicious software programs would have been installed on your computer.
· Your computer might not have the latest version of Flash player, Shockwave player and Java Runtime installed on your computer.
I would suggest you to follow the troubleshooting steps below to help resolve your issue.
Step 1: -
· Download and install Microsoft Windows Malicious Software to remove any unwanted malware program from your computer, please see the link below to download it.
http://www.microsoft.com/downloads/details.aspx?familyid=ad724ae0-e72d-4f54-9ab3-75b8eb148356&displaylang=en
· See this link for more description about Windows Malicious program removal tool - http://support.microsoft.com/kb/890830
· Download and install latest version of Java Runtime Environment, Flash player and Shockwave player.
Step 2: -
Perform resetting Internet Explorer 8 settings to default will reset Internet Explorer as it was first installed on your computer. Please see the link below,
Reset Internet Explorer 8 settings
http://windows.microsoft.com/en-US/windows-vista/Reset-Internet-Explorer-8-settings
Note: - Resetting Internet Explorer 8 will delete all the stored passwords and history.
Will not let me see videos on Youtube becaause of flash player not installed When i installed it it said You need a newer version of windows.
What version of Window do you have ?
Win 98, Win 98se, Windows 2000 don't have newer program written for them. Most programs only support XP / Vista. If you have flash Ver. 6 and YouTube requires Ver. 8 or above. You're out of luck. I've had to dump all my Win98/ Win 2000 PC because of that problem in my school. Web is all Flash/ Shockwave anymore.
MACRO MEDIA FLASH PLAYER WHICH SUPPORT SWF FILES IN WINDOW VISTA AS IT SWF FILES ARE NOT BEING SUPPORTING IN VISTA AND SO ALSO ANY SWF FILES CONVERTOR...PLZ REVERT ME BACK IN MAIL ID TO SOLVE THIS...
I came accross this fix.
It worked for Firefox 3.0.3 ,I.E. 8 Beta 2, Opera 9.52, and Google Chrome Dev Release: 0.3.154.0.
For Vista (32 bit):
1. Open Computer.
5. Right-click FlashUtil9x where x is some letter.
For Vista (64 bit):
1. Open Computer.
You should be able to download and install Flashplayer 10 (now by Adobe): http://get.adobe.com/flashplayer/
and if it still won't work correctly, apply this fix: http://thetechangel.com/blogberry/2008/10/adobe-flash-player-10-fix-for-vista-xp/
Finally, a forum where other Vista users discuss the problems they've had.. http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?catid=184&enterthread=y&forumid=44&threadid=1243464
A converter: http://www.sothinkmedia.com/swf-to-video/?gclid=CO72_4X7wJkCFRo-awodAVFAuw
or freeware: http://majorgeeks.com/google_search.html?cx=partner-pub-6960825562757852%3Aecswas-url5&cof=FORID%3A11&ie=ISO-8859-1&q=convert+.swf#0
That ought to sort it out, one way or another. If you need any further assistance, please post back and I'll be happy to guide you through the process.
If this solves your problem, please take a moment to rate this post.
Thanks, and good luck!
Grand Canyon Tech
Grand Canyon Tech
