This will either be a purity fault or as this is an old TV the tube (CRT) will be at fault which would not be worth spending money on. You would need to call a service engineer to check if it is a purity fault, but as this is a quick an easy repair it should only cost a call out charge. You would not be able to fix this yourself as a special tool (de-gauss coil) is required.
