Question about Seiko SNA553 Alarm Chronograph
Remove back fro wrist watch to change battery
  • 183 Answers
Generally Seiko uses a pop off back and a screw off back. The pop off back will be smooth and have no indication of how to come off. The screw off back will have several rectangular notches around the back where the prongs of a watch wrench fit.
Before you begin you should know that this watch is water resistant and sealed to 100m. This means you do not have the equipment to reseal the watch and you void Seikos warranty. Also, the titanium models are more difficult to seal the back because of the hardness of the steal and the powder coating. They generally require that you replace the rear seal to make the watch water resistant again.
To remove a pop off back use a watch knife and press it straight into the separation between the case and back. Do not use a sharp knife or widdle back and forth as this may damage the surface where the seal is or make burrs. Once you have driven the knife straight in you can move around the back repeating this until the back is completely off.
To remove the screw off back place the watch wrench in the grooves at 10, 2, and 6 o clock. Make sure the prongs are pointed inward toward the wrench the same direction to avoid slipping and damaging the watch. Turn counter clockwise until the back is off.
When taking the back off in either case you must be careful not to slip and scratch the coils or vital parts of the watch. These damage by touch and this will cause the watch to not work. Also, most chronographs require the watch be AC'd. The instructions for this are usually on the back lid of the watch or in the owners manual. If you make a mistake ACing the watch you can short it out or break the circuit board.
Because of the complexity of this seemingly simple task i recommend going to a watch maker/ technician to avoid complications that could end up costing you much more in the long run.
Posted on Sep 22, 2009
6ya staff
SOURCE:
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
HOW TO CHANGE BATTERY
mcdevito75 here, Depending on your watch itself, Basically you"d remove the back cover, then release any hold down linkages on the battery, then replace the battery, hold down linkages and cover. The BEST BET is to look for a small watch repair shop in your area for this battery replacement as it may take special jewelers screwdrivers to change the battery.
Jul 10, 2010 | Armitron 0501643FA Wrist Watch
mcdevito75 here, With the tool needed to remove the back cover, and the time and effort involved, the best bet is to look for a small watch repair shop in your area to change the battery.
Jul 03, 2010 | Polar F6 Wrist Watch
How do I change the battery in my Timex Iron Man Triathlon? I removed the 4 screws in the back but cannot remove the cover because of the overlap of the wrist band.
You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
Dec 19, 2009 | Timex Sports Ironman Triathlon 100-Lap...
How do you change the battery on an ebel watch
Unscrew or pry off the case back. Remove the metal strap holding the battery in place. Sometimes you have to remove screw in the metal strap. Look on the battery for the type and order by that number. Put back in with fingers or plastic tweezers. Do not use metal tweezers as it will short the battery.
Dec 14, 2009 | Ebel Classic 1157111/0225 Wrist Watch
How do you change the battery in a series 3100 luminex navy seal
Take it to a reputable jeweler, this model has a screw off back and you need a special tool to remove it...good luck :)
Jan 26, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
Removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
Seiko SNA553 Alarm Chronograph Logo
2,055 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
