I have a 4GB Transcend pen drive ..pen drive icon is getting displayed when i plug it .but, when i try to open the drive , "please insert into drive I" is the error i am getting...I am unable to format it .I tried formating from command prompt . but getting some ioctl error ...Pleas help me...
Go to www.transcendusa.com. You will find an user friendly menu. Give the location of your country e.g. India. Then the product. Give USB flash drive. Then the type of flash drive V30 or whatever. You will find an onlinerecovery popping up. In that scroll down and you will find download links of onlinerecovery.exe file. According to your flashdrive & operating system you download that file & run it. Plug your pendrive and the software display is self-explanatory. That way you should be able to recover your pendrive.
S.V.Raghavan, Bangalore
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
