If you do not take the racks out they will discolor and not slide in and out as well as before. Do not use the stove for any other purpose during the cleaning process. Oven temperatures reach over 900 degrees during cleaning. Open a window to vent out the fumes from cleaning.
Ronald, the following part number is the closest thing I can find while using your model number: WB48T10093. I looked on the website repairclinic.com. Hope this helps.
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts
on time or your order is free. Return any GE range/stove/oven part for
any reason for one full year. Customer service for GE range/stove/oven
parts is available 7 days a week. More than one million parts available.
We stock the GE range/stove/oven parts you need for immediate shipment.
We have more than 200,000 high-resolution part photos.
Your problem is with the oven ignitor.
Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Is this my wife asking this ? lol, i had the same arguement with her, dont leave the racks in, it will tarnish them possibly bend them,that stove gets up to 900 F
you will neeed a new ignitior
its a pretty easy repair
take out the racks
take out the bottom of the oven
you should see the ignitor
pull ou the drawer you will see the connection
disconnect it
make sure your very careful with the new one they are very brittlle
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected
wrong). Check for stuck lock switch.
