Most hp deskjet printers are not enabled for double-sided printing. This feature is common with laserjet printers. So if you are using a deskjet, please you may to manually print your double sided.
If your printer is a laser jet you will find the selection under your print menu. Press ctrl P (keyboard) and the print menu appears. Click on each tab to see which one is contains the double-sided selection button. select it and print. The tab should be titled "Basic" depending on the your printer.
If your printer is a deskjet, go through this procedure to see if your model is enabled for double-sided printing and enable it.
