There is no need for developement Vista will support many users. You will want to get a list ready of users then you have some work to do in order to administer them.
Login as Administrator
Go to Control Panel
Click on User Accounts and start adding users. Becareful here make sure that you make all the user accounts private so that nobody else can access each others information.You will also want to make sure that all user accouonts are at the User level not Administrator. You can assigne each user the same generic password as the Administrator giving the option to the user to create their own on first login.
The method of doing so will be as follows:
Once you have completed creating all the users accounts you will want to go back to Control Panel then select Administrative tools
Then Double Click on Computer Management on the left you will see a catagory called Users and Groups expand the list and select users. Now you will need to go through each of the users that where created and double click on them one at a time on the General tab you will take the check mark out of Account never expires then you will add a check mark to User must change password at next logon. This way your users can select a password that they will remember.
Ther is some work in administering this however as people will forget their password and such. Good Luck!
Testimonial: "thanks a lot"
