I have a similar problem with my d100. I press the shutter halfway to auto focus. It appears in focus in the viewfinder, but when I look at the photo later the subject is not in focus, but the background is. The really perplexing thing is sometimes, when shooting the same event and same kind of photo, it is in focus. Any ideas?
Seems like your camera is choosing the focus point, not you. Be sure that when focusing on your subject, the little square in the viewfinder id dead-on that focus point. Otherwise, the camera will focus on wherever that square is.
Change your focusing setting to spot focus. Then, focus on your main subject, keep the button half-way pressed while you re-compose the shot and then press it the rest of the way. Does that improve the shot?
This issue can occur in the following circumstances:
The subject is too close to the camera lens
Insufficient lighting
Subject movement
Camera movement
Incorrect camera settings
Incorrect camera operation
Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus.
Make sure there is enough lighting to allow the camera to focus on the subject.
Make sure the camera settings are set appropriately.
When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position.
If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting.
If your camera has a SteadyShot/anti-blur function, ensure it is enabled.
Aim the camera at the subject.
Press the shutter button halfway down.
NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture.
Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Could this be the auto focus? Try this, put what you want to focus on in the center of the screen, in the [ ] part. Lightly press the shutter button and keep the pressure on. The camera will focus and then wait. If you now press the shutter button all the way down the camera will take the picture.
The r06 just means the camera can take 6 more pictures quickly before the picture buffer fills up. Unless you are using the fast drive mode this will not matter to you.
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Auto Mode
In this mode, all you have to do is press the shutter button and let the camera do everything else.
1. Turn the camera on.
2. Turn the shooting mode dial to .
3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
Two
beeps will sound when the camera has finished metering, and the
indicator will light green or orange. If the LCD monitor is on, the AF
frame will appear green.
The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
6. Press the shutter button all the way.
You will hear the sound of the shutter when the shutter activates.
The picture appears for two seconds on the LCD monitor, if it is on.
The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode).
(SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway.
C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway.
(MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder.
SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
