Before you Begin
Installation
This section will walk you through the installation process. Placement of the router is very important. Do not place the router in an enclosed area such as a closet, cabinet, or in the attic or garage.
Please configure the router with the computer that was last connected directly to your modem. Also, you can only use the Ethernet port on your modem. If you were using the USB connection before using the router, then you must turn off your modem, disconnect the USB cable and connect an Ethernet cable to the Internet port on the router, and then turn the modem back on. In some cases, you may need to call your ISP to change connection types (USB to Ethernet).
If you have DSL and are connecting via PPPoE, make sure you disable or uninstall any PPPoE software such as WinPoet, Broadjump, or Enternet 300 from your computer or you will not be able to connect to the Internet.
You should not need to install anything. just reset your router with the little button right next to where you plug the power adapter. This should reset the device to simple manufacture default setup with no WEB security then go to your mac and turn your mac plug it in to your router with ethernet wire and enable local Area network and disable wireless internet connection. When you are connected with wire, To secure your network first you need to find your ip address it is usually 192.168.0.1 but sometimes it might be differant Open your system preference, and then click on
network.This will take you to your active connection.From here you want to Lookunder the word status. Here you will find your IP Address.
Depending on your
router settings yo may get a different IP address each time you connect. So check this before relying on it to stay the same
Type in that ip address on your internet browser and enter it should go to a log in screen to your router's hosting To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
You may also connect using the NetBIOS name in the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. once you connected enable wireless access and configure a web or Wpa secured connection and generate the web key aftre the web key generated look at the one is checked on the right side which is usually the first one wire that key down and do not loose it change your connection name change the log in name and password if you want save these settings and log off. go back to your mac and disable local area connection and re enable wireless internet connection unplug the ethernet cable and search for your connection you just named. type the web key when it is asked and save the connection after connection astablished. And you are done.
in control panal iv disable the nvidia device the usb cable come with a disc set up and i have used that to install the modem by ( usb ) but as iv posted iv still got 2 inernet conections
iv gone to control panal network connectoins and in there iv got local area connection 2 usb cable modem 351000 and local connection 8 disable,firewalled nvidia nforec 10/100 mbps ethernet this one is desabled iam on the internet now but when i try to go on windows update i get this
Last diagnostic run time: 09/22/09 14:00:50 Network Adapter Diagnostic
Network location detection
info Using home Internet connection
Network adapter identification
info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN
info Network connection: Name=Local Area Connection 8, Device=NVIDIA nForce 10/100 Mbps Ethernet , MediaType=LAN, SubMediaType=LAN
warn This machine has more than one Ethernet or more than one Wireless adapter
info Redirecting user to support call
HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
warn HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn HTTPS: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn FTP (Active): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn HTTPS: Error 12037 connecting to www.passport.net: The date in the certificate is invalid or has expired
info HTTP: Successfully connected to www.hotmail.com.
error Could not make an HTTPS connection.
error Could not make an FTP connection.
