Cameras Logo
Posted on Sep 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot download pictures to computer
Canon Powershot SD1100 IS Elph camera cannot download pictures to computer (HP notebook). Says it "cannot detect camera" when connected with USB cable.
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Sep 21, 2009
Anonymous
Expert
Level 2:
Answers
69
Questions
0
Helped
20406
Points
202
Check your device manager on the computer to see if your if your usb driver are loaded and have no conflicts, u could also have a bad cable don't load the camera software on to the computer if you did uninstall the software from the PC and then plug the camera in and let windows recognize the camera if this does not work change the cable your using, GOOD LUCK
2helpful
Trying to upload pictures to my computer from my canon powershot sd1100 IS digital elph camera but it says "communication error" how do i fix this so i can upload them?
This type of problem arises many times,at first they work but the more you use them the terminals tend to loosen up,even if the camera is new.So most of the time my best solution for that is to purchase a multiple memory card reader(usb 2.0).Most don't require any installer,just plug the reader to your computer and slide in any memory card you have and you will be able to upload any media you want.What I have is Ohm USB multi card reader/writer,it has been doing it's job since I got it.
1helpful
Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
How can i upload pictures from my digatal cameral
Connect your USB cable to the computer. Turn the cam on and the computer should automaticly notify you of the cam.
5helpful
2answers
Have Canon Powershot SD550 but no software
Here is a clickable and direct link to the Canon web site with the software you need for your Canon Powershot SD550 Digital Elph.
Hope this helps you!
- CBR2009
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=145&modelid=12466#DownloadDetailAct
1helpful
2answers
I have lost my Digital Camera Solution CD ROM for canon power shot SD1100 IS - is there anywhere on the web that I can download this?
You can download it from Cannon, support,downloads, choose model. This is horrible software by the way. Once you have the basic driver for your model installed(Windows has many drivers pre-installed for many cameras), you are better off using MS picture and fax viewer. It does not have the lengthy and overly complicated stuff that comes with the camera. Anything that comes with the camera for free is usually junk written by grad students to practice their software engineering.
Camera Is Not detected by computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
