The air is not coming through the vents when switch is turned to o. You can hear the unit start up and the fan is turning on the unit, but no air is blowing through the vents. It is a rudd model#rrka-a024jkobe
The evaporator coil may be freezing up, not allowing air to pass. Could be caused by a dirty coil, dirty filter, low freon level, or any combination of these.
Is the unit running outside? did you check the breaker? Ruud units often times will have a reset bitton on the outside unit to the left of where the freon lines connect. It is a high pressure switch if it comes on when reset make sure the coil is clean and the fan runs(outside)
