If its an LCD or plasma tv, it sounds like an invertor problem. (the invertors run the backlights to light up the screen). I would advise getting this repaired sooner rather than later, because if the invertor fails completely, it may damage the backlights and render the TV useless. if it is a CRT (tube) TV, then its possibly a bad solder joint near the HT area of the main board.
Clock Setting Procedure
1. Press and hold the time button until the hours blink.
2. Adjust the hours by turning the right side Tune / Audio control.
3. After the hours are adjusted, press the right side Tune / Audio control to set the minutes. The minutes will begin to blink.
4. Adjust the minutes using the right side Tune / Audio control.
5. To exit, press any button/knob or wait 5 seconds.
I hope that helps!
Audio control.
begin to blink.
control.
Not sure but I think the radio needs to be off when you do this but don't quote me on that. I hope this helps you and good luck.
