I find no way to remove demo mode. However, the "work around" is as follows: Press the G button. Then, the B setup menu.
If Release locked is selected, the shutter-release button is only
enabled when a memory card is inserted in the camera.
Selecting Enable release allows the shutter to be released when
no memory card is inserted, although no pictures will be
recorded (they will however be displayed in the monitor in
demo mode). The aforementioned quote from page 250 of the manual means you avoid the problem of demo mode not saving pictures by selecting Release locked. You see, demo mode normally doesn't mind no memory card, where pictures are saved, NOT being in the camera! No card, no save, even though demo shows the pictures.
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Go into the menu and try to find "reset" to get back to factory default settings. If you can't, try this...remove the card and battery...press every button....leave it alone for 20 minutes....insert the battery and the card....turn it on.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
You can download a user manual here. Your problem, however, does not seem to be related to the camera, but to the SD card. Take the card out and look along the edge for a small 'switch'. This switch will have a 'locked' and an 'unlocked' position. Make sure it is 'unlocked'. If you still get the advisory, try another SD card. (Sometimes those little 'switches' fail.)
Did you unlock the SD card or accidentally lock it again?. There is a switch on the SD card to unlock it. Try this and then let me know how you make out.
Sorry, but as far as I know, Hitachi camcorders cannot record video directly onto an SD card. You have to set the camcorder to DVD. It can only record video and pictures on a DVD, and only pictures on an SD card.
