Need Help Installing U-Turn Trimmer Head on Echo SRM-210
I've found the ECHO manual and the instructions that came with the U Turn head less than helpful. It appears that the bolt/shaft is too to simply put the new head on. Any suggestions?
Thanks Doloff. SRM 210. Problem solved. I also posted to Echo's website and they send me step by step instructions with pictures which are now posted to Echo's websiteThanks Doloff. SRM 210. Problem solved. I also posted to Echo's website and they send me step by step instructions with pictures which are now posted to Echo's website
What model number is the trimmer? Straight shaft Echos are modeled: SRM-_ _ _ Curved shaft Echos are modeled: GT-_ _ _What model number is the trimmer? Straight shaft Echos are modeled: SRM-_ _ _ Curved shaft Echos are modeled: GT-_ _ _
You can't post conmments that contain an email address.
Re: Need Help Installing U-Turn Trimmer Head on Echo...
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense. There are instructions on the inside of the package, however that is how to string the line.
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
Please see page 14 of the following manual for detailed instructions (including tools to use) in order to accomplish this procedure. You see, you have to lock up the gear drive so you can get the head back on the threaded end of the driveshaft.
First off you have to have the blade conversion kit PN 99944200418 or 99944200418
Then you must install the kit that involves removing everything down to the angle drive mounting plate.
I have the same model. Home Depot assembles their trimmers then sells them, so I didn't get the stuff that comes with it. A 3/16" punch works perfectly.
I know I'm replying to a old post, but this might help others. My Echo GT225 might be similiar. Once u are down to the thread bolt & the round shaft part that spins in ither direction, u need to thread back on the line spool, at lest the botton part of it to hold the thread bolt in place. Then start turn that rounded part that normally just spins, it will start to thread off, as you are thrreading it off you may have to also start threading the line spool part off as well at the same time. After that you will need the tool that takes off the C ring clamp thing that's underneath. I couldn't find any info on this online, I just kept on playing with it until I figured it out, UGH.
The bolt/shaft is too... ??? WHAT ??? ...to simply put the new head on
