What causes vertical colored lines on a TV screen? When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
https://removeandreplace.com/2018/05/01/tv-has-different-color-vertical-lines-on-screen-how-to-fix/
SOURCE: 1/2 picture on my vizio 42" TV
Are you under warranty? Chances are real good that you need the signal board....the one with the rca jacks and rf connectors. This may be pricey $$$$$ but will surely repair the problem.
SOURCE: 42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
SOURCE: I HAVE A VIZIO 42' LCD TV WITH A 8' BLACK BAR
You panel has a TCON (timing control) board which feeds the panel connector (1 or 2) inside the LCD panel, the picture information is then broken down inside the panel assembly via a connection board. You have 2 options: Replace the panel or toss out the TV. If you are going to toss out the TV, you may as well make a project out of it and attempt to fix it... what's the worst that can happen? You break it? It's already broken. So here's what I would do. Take the TV apart (photograph as you go if you are worried that you will forget what goes where). Remove the LCD panel and place it in a clean area. I would clear the kitchen table, cover the table with a soft blanket and then place a bed sheet on top of that to keep the dust and fuzzies to a minimum. Place the LCD on your work area and patiently and carefully take it apart. When you get to the connector board inside the panel, disconnect the panel connection directly above the black bar (should be a hinge style connector, a tab will flip upward to release the ribbon cable) and then reinstall the connector. You need to be careful here, these cables can tear if you get too forceful with them. After you reinstall the cable, go ahead and reassemble the panel and then the TV. If this doesn't fix it, you are back to option 1... replace the panel or the entire TV. Option 1 is more often the TV as the panel cost is close to or more than the TV. Here's an illustration I made for you to give you an idea of what the connection board is doing:
Then signal comes in on the red connector from the TCON then goes out to the panel on the yellow connectors. This is just an illustration, your TV may be a bit different, but the principle is the same. I hope this was helpful, best wishes.
Testimonial: "I ALREADY DID WHAT YOU SAID AND EVERY THING IS THE SAME, THATS WHY I WAS WANDERING IF THE CONTROL BOAD COULD BE BAD"
SOURCE: My Samsung hdtv model LN46B650
You should download the PDF and learn what the T-CON/LCD panel failure can do to what you see on the screen. http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: color lines on 42inch vizio
Hello
The y SUSTAIN board to your tV is faulty. It should be repalced.
