SOURCE: Bernina 180 with Firmware 2.08 - can it run DesignerPlus 5 or 6?
You will need to update the software in the machine, to a min of version 3.08 this can be done at BERNINA dealer (usually free of charge) once this is complete you designer will fully be compatible. WHEN YOU TAKE YOUR MACHINE IN TO BE UPDATE DO NOT FORGET TO TAKE THE EMBROIDERY UNIT IN AS WELL AS IT CONTAINS ITS OWN SOFTWARE
SOURCE: USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
SOURCE: can you upgrade Bernina artisa designer plus
The Bernina site has the official downloads of software updates and upgrades which are available. The site needs your specific ino, which I don't have, so I am directing you to their site.
http://www.berninausa.com/news_search-n32-sUS.html
I did find several warnings regarding using other downloaded software for Bernina machines.
Good Luck!
SOURCE: I have a Bernina 180
Unfortunately no, I think that the 185 and beyond use the same emb module. The 180 if I remember correctly, has the memory and card reader in the module itself and may have a different plug. I do know for sure that the 180 hoops will definitely not fit on the newer modules. Sorry to disapoint, Allen
SOURCE: How can I purchase a
Don't think they offer that nor was it an option. They have a serial interface to download or upload designs to or from the machine's embroidery option. Check out a USB to Serial onverter and connect the PC to the machne. I used a Dynex brand cable and it worked. Use Bernina'a Artlink software (it;s free) and connect that way. Very easy to use.
